H22 Oil
H22 Oil
What is the best weight oil, or what are the best results that people have had for an H22? I am running 10W-40 non-syn right now. Should I be using synthetic? I have heard some conflicting stories.
i would persoanlly use the 5w30 or 10w30 that honda specifies for the engine, and i am partial to mobil1 though i only use synthetic because i dont like to change the oil as oftne as i should...
Re: (jhelms54)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhelms54 »</TD></TR><TR><TD CLASS="quote">High Compression pistons make a difference?</TD></TR></TABLE>
If they are new I would use 5w30 petroleum oil for the break in process if that is needed.
Edited because my last responce was fucked up.
Modified by EsQueue at 12:43 PM 4/20/2006
i think the oil pump and age are the most important factors in decing what oil to use, then the intended use of the engine. the oil pump and oil galleries were designed around 5w30 or 10w30 so it stands to reason with a stock oiling system and stock oil pump you will overall see your best results with th stock weight oil.
HUBB
12
04-24-2004 01:53 PM
