Swap problem, continued
Well i just put a typeR in my Sol.. well i am having problems with the wiring. Well the motor went in great, runs good and all. But, my gauge cluster isnt working, it keeps blowing fuses. Well i got under the dash, behind the fusebox, and got to looking around. Well i found a yellow wire on the back of the fusebox coming out of a plug going up to the firewall. The wire was burnt/melted looking right at the fusebox about 4in. and at the firewall and on into the engine bay. At the plug on the driver side its burnt almost to the plug, but on where the plug joins to the plug on the engine the wire on the engine side look fine. And also the other plug from the motor the has a flat end and no connection point, the wires on that plug look as if someone has cut them all and stuck them back together, looks like crap. if i can ill get some pics, i know this is confusing but im without a cam at the moment, and a car.
EG93si
Oct 26, 2005 09:52 PM
boosted_zc
Aug 6, 2005 10:02 PM
