97 JDM engine harness question!
Old Apr 24, 2006 | 01:15 PM
1 sLoW hAtCh's Avatar
Default 97 JDM engine harness question!
Hey I was wondering if anyone here can tell me how do you convert the jdm engine harness to the usdm spec harness? Is this possible or do I have to get a usdm itr harness? Or can I just use my harness which is a cx hatch? Thanks in advance.
Modified by kraz3eaocp at 6:35 PM 4/24/2006
Old Apr 24, 2006 | 01:34 PM
ReDHaTcHyGuy's Avatar
Default Re: 97 JDM engine harness question! (kraz3eaocp)
what kinda car are u trying to put it in and what motor?? the jdm harness is rhd it will not work
Old Apr 24, 2006 | 03:17 PM
Default Re: 97 JDM engine harness question! (ReDHaTcHyGuy)
i'm puttin it in a 93 hatch and its a jdm 97 itr. U sure it won't work? Anyone has other opinion on it.
Old Apr 24, 2006 | 05:35 PM
goin da bed bump for n answer.
Old Apr 24, 2006 | 06:45 PM
what model hatch?? u can use the 92-95 ex/Si harness an just add the extra wires....
Old Apr 25, 2006 | 10:40 AM
wat wires would that b? This is my first swap and I'm a ameuture on it.
Old Apr 25, 2006 | 04:20 PM
So anyone, Can I or Can I not use my 93 Civic CX Hatch harness for this swap?
Old Apr 26, 2006 | 11:12 AM
bump for help and answer. First timer doing a swap hea
Old Apr 26, 2006 | 12:50 PM
if u use your harness you will have to add vtec ,add wires for the 4 wire o2, and knock if ur using the jdm ecu... u can get a p28 chipped and use a ex harness like i said and you will only have to run 2 wires to the ecu for vtec
Old May 12, 2006 | 06:46 PM
95jdmcivicex's Avatar
i am doing the same thing bui i am cutting the ends off the jdm engine harness and rewire the harness frome the 2 end i got at a juck yard fro free cuz i do not have my stock harness..i hope it will work
Alan920
May 18, 2010 11:04 AM
hannslebo
12
Jun 4, 2009 12:24 PM
nutsack
Oct 26, 2003 05:04 AM
cmk804
May 9, 2002 03:16 PM
