need help b18b in to a 91 crx si please help
first time doing swap and ran into a couple of problems with swaping a obd1 b18b into a crx si 1991 obd0
the first problem is that the half shaft i have from a 91 integra does not bolt up
secound got to wire up the plug for distrupiter and it says connect to a thick white which one is the thick one??
third is there a special way to swap over the injector plugs and how do i block off the resister block thanks and please help
you think this motor should be quick with all those parts
parts list
91 crx si
94 b18b
obd0 to obd1 conversiosn harness for the ecu
have a ls cable tranny
type r under drive pulley n1
fidanza 7.5 lbs flywheel
exedy stage 1 clutch
dc sports 4-2-1 header
aem cold air intake
exhaust
parts list
91 crx si
94 b18b
aem cold air intake
exhaust
Re: need help b18b in to a 91 crx si please help (g-ride-si)
nevermind i know its you. this is ryan. all i can really help you with there is the resistor box. you just take it out and run the wires straight as far as i know.
I dont see why the shaft wont work. why doens it fit?
Your phone doesnt work i tried to call you. call me.
Modified by g-ride-si at 6:37 PM 4/13/2006
ddubtoille
06-28-2009 10:49 AM
95_red_dc
04-13-2006 04:51 PM
