What is a good crank to use in a B20 LS/VTEC??
Old 04-07-2006, 11:14 AM
master honda tech's Avatar
Default What is a good crank to use in a B20 LS/VTEC??
I was wondering if anyone has either built a B20 LS/VTEC or has had experience with them. Is the stock B20 crank strong enough to handle boost? Are there other B series cranks that will work better? lemme know.
Old 04-07-2006, 01:35 PM
NXLude's Avatar
Ive seen some big power cars use ls cranks
Old 04-07-2006, 07:00 PM
Default Re: (NXLude)
ls cranks? whys that?
Old 04-09-2006, 06:16 PM
Default Re: (master honda tech)
Old 04-10-2006, 11:12 AM
whit3's Avatar
i gotta crvtec in my ek and just went with with stock bottom end from the b20. does fine lots of pull and play. i would say you are fine to leave it. iv been told both head and crank of a stock honda can handle 500hp. unless you are ganna do some kinda forced then the stock crank is ok. if you are ganna do forced induction then i might suggets a new crank. just my 2 pennies
Old 04-10-2006, 04:39 PM
Default Re: (whit3)
thanks
Old 04-11-2006, 10:20 PM
so stock B20 crank can handle like 14 psi?
Old 04-12-2006, 08:52 AM
I'm really 2slow
2fast4u831's Avatar
b20 crank is the same as the ls crank cranks can take plenty of abuse. Its the rods and pistons you should worry about.
Old 04-12-2006, 06:33 PM
Honda Bull's Avatar
Default Re: (2FAST4U831)
Honda cranks
In fact, Honda bottom ends Just needs better sleeves I suppose.
Old 04-12-2006, 08:24 PM
Default Re: (Honda Bull)
BAM
Old 04-13-2006, 06:25 AM
Hybrid-Fusion's Avatar
Default Re: (whit3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whit3 &raquo;</TD></TR><TR><TD CLASS="quote">stock honda head stock honda can handle 500hp.</TD></TR></TABLE>
Old 04-13-2006, 06:29 PM
Default Re: (Hybrid-Fusion)
Old 04-13-2006, 10:21 PM
RTFM
v4lu3s's Avatar
you should use a chevy crank.
Old 04-14-2006, 06:19 PM
Default Re: (v4lu3s)
should i?
Old 04-14-2006, 07:23 PM
oneI's Avatar
Default Re: (whit3)
ls and b20 crank is the same. i would suggest sending out the crank for a high speed balance and polish. the crank will be fine for boost, but the sleeves on b20's suck and can easily crack even on low boost.
Old 04-17-2006, 07:00 PM
Default Re: (oneI)
Nice!!
amios
08-19-2009 02:56 PM
ss396rat
06-05-2009 11:03 PM
jdm92teg
04-13-2005 01:20 PM
Quick Reply: What is a good crank to use in a B20 LS/VTEC??
