EK with LS Automatic Swap!!
Old Apr 24, 2006 | 09:23 AM
chicows18's Avatar
Default EK with LS Automatic Swap!!
So im doing an EK with an LS Automatic swap. Got the motor in. Fabricated some mounts and now its sitting in there. The question now is how do I go about the wiring. The original EK wire harnes goes right into the firewall and plugs right into the ECU. The LS automatic wire harness kinda just stops right at the strut tower. Another problem with the LS wire harness is that it does not have the second plug that is right by the brake booster unlike the original EK harness. Has anyone done this swap and if so, how did you go about doing the wiring. Ohh by the way, its OBDII HX coupe 98.
Modified by chicows18 at 10:44 AM 4/24/2006
Old Apr 24, 2006 | 04:00 PM
dcRay's Avatar
Default Re: EK with LS Automatic Swap!! (chicows18)
Maybe be off the topic, but are you looking to sell your automatic transmission. I am local?
Old Apr 24, 2006 | 04:27 PM
mikegeezy's Avatar
Default Re: EK with LS Automatic Swap!! (dcRay)
use the ek wire harness connect to engine and run any wires for stuff that the ek harness dosent have example iab and egr ect.
MastaFlyMason
Feb 7, 2018 05:28 PM
rx7turbo287
Jul 8, 2017 05:28 PM
EK_HATCH509
Apr 4, 2012 03:08 AM
