Help me wire My gsr
Help me wire My gsr
Hey was up guys... i swapped a 95 gsr motor into my 93 DA. I am using the hydro tranny and the innovative mounts kit. I did all my vaccums and wiring and it is running pretty good.. once in a while it will drop like it wants to turn off.. then pick back up and be steady for a while.. then drop again.. so that is the only problem i have now. But for now my question is about wiring up my vtec, knock, and butterfly. I have a 93 so it is obd-1 and i am using a stock p72 (gsr ecu) I have the diagram to where the knock and vtec's go.. but where does the butterfly go???? Also on my ecu harness.. are there gonna be wires coming out of those spots that i can juss cut and splice a new wire into? Or are they empty slots and I have to get buy a pin and run it in there?? And do I have to move any other wires around??? thanks
