Engine swap help......
Old Apr 24, 2006 | 05:49 AM
97exd16's Avatar
Default Engine swap help......
i twisted a bearing in my d16 so now i'm looking B16A Gen1 OBD0 Complete Swap (LSD)....swap costs 1949.99.....there is also a B16A Gen2 OBD1 Motor Swap (LSD)
it is a little bit more money (2649.99) but wut is the differance between these two motors??? i'm pretty new to the whole engine swap deal.....i live in a small town and the street racers basically consist of a 96 firebird....96 cavalier....mid 90's fwd turbo talon and a 220hp saab 9-3 turbo......so please....HELP ME OUT....i need to know the diff asap cause i'm going to be buying either of these in the upcoming month..
Modified by 97exd16 at 7:01 AM 4/24/2006
Old Apr 24, 2006 | 05:59 AM
97exd16's Avatar
Default Re: Engine swap help...... (97exd16)
bump
Old Apr 24, 2006 | 09:47 AM
Too Drunk 2 See's Avatar
You just need to find a wrecked 99-00 Si, if you have 97. There are too many differences for me to type out right now.
Old Apr 24, 2006 | 10:39 AM
Slopoke's Avatar
You should at least get the second gen obd1 motor. The 1st gen b16 comes with the wrong kind of tranny. There are mount kits and cable to hydro conversions available so you can make the 1st gen work, but by the time you pay for all that, you could've just got the 2nd gen(and had 10 more hp).
If you live in a small town, they you probably dont need to worry about emissions or saftey inspection.
So I would:
-Purchase the obd1 swap
-you need the rear tranny bracket and timing belt mounting bracket(you need the brakcet that bolts to the block) from a '99-'00 SI.
-you need to use your stock '97 engine harness and put it on the obd1 motor(this will include changing distributor plugs, injector plugs, and alternator plug).
-Then buy a obd2a-obd1 jumper harness and plug in the obd1 b16 ecu.
Old Apr 26, 2006 | 02:53 PM
97exd16's Avatar
Default Re: Engine swap help...... (Slopoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke &raquo;</TD></TR><TR><TD CLASS="quote">If you live in a small town, they you probably dont need to worry about emissions or saftey inspection.</TD></TR></TABLE>
yeah emissions really dont matter but i'm looking at the complete swap from password jdm......does that cover everything???? i know that bolt on turbo kits dont come with all the little fixins and i would think thats the same for a engine swap but yeah....help me out
Old Apr 26, 2006 | 06:11 PM
97exd16's Avatar
bump
Old Apr 26, 2006 | 07:04 PM
Slopoke's Avatar
The complete swap should include: complete motor, tranny, ecu, engine harness, axles, shift linkage and all the mounts.
You'll have to buy the rear tranny bracket, timing belt mounting braket, and jumper harness seperately.
tncivic-dvsb
Mar 4, 2005 07:14 PM
capitan-d
Apr 18, 2004 11:44 AM
Soled Out
Sep 8, 2003 02:16 PM
LilDevil
Mar 3, 2002 05:35 PM
cannondale
11
Oct 5, 2001 02:13 PM
