B18c1 into a 94 civic coupe
I have a 94 civic coupe ex. Im planning on dropping an engine into it and I was wondering if the b18c1 would drop right into my car with everything that comes with it from hmotorsonline like a b16a would, or if i would have to buy extra stuff or do different things to get it to work. If anyone knows about this or has actually done it from hmotorsonline please help me out. Thanks
Re: B18c1 into a 94 civic coupe (athbaseball23)
since you have a 94 civic ex your in luck ! all you need is the back bracket for the tranny! side tranny mount and driverside mount bolt to the b18c1!
the ex harness will plug up to the b18 but wires will need extending and the addition of the iab's will also have to be wired up.
the swap from hmo will come with axles,mounts,linkage and acceries!
pretty much straight forward swap! as lon as you use a stock b18c1 header with a b18c1 cat the exhaust will bolt up as well!
