LSD Trans Problems NEED HELP
Old Apr 10, 2006 | 07:44 PM
WhiteHB15LSD's Avatar
Default LSD Trans Problems NEED HELP
I have a swapped D15b hatch and just put in an LSD tranny. Last week the axle popped out of the trans. The shop that did the swap did not put in an intermidiate shaft. Is this whats causing the problem? and if so how do I go about finding an intermidiate shaft and how do I put it in? Any response would be helpful.
Old May 6, 2006 | 05:24 PM
SkRiBLaH's Avatar
Default Re: LSD Trans Problems NEED HELP (WhiteHB15LSD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteHB15LSD &raquo;</TD></TR><TR><TD CLASS="quote">I have a swapped D15b hatch and just put in an LSD tranny. Last week the axle popped out of the trans. The shop that did the swap did not put in an intermidiate shaft. Is this whats causing the problem? and if so how do I go about finding an intermidiate shaft and how do I put it in? Any response would be helpful.</TD></TR></TABLE>
D series does not use intermediate shaft. only one long one and one short one.
Old May 7, 2006 | 10:17 AM
egsleepercivic's Avatar
if its an OBX LSD that is most likely the issue, search OBX LSD, that may shed some light on your issue
gl
97grnrs
Mar 19, 2006 06:53 PM
JeffBro
Aug 10, 2005 08:59 PM
b2Ovtec
Dec 10, 2004 10:28 AM
vteg97
Mar 6, 2004 07:05 PM
