Need help with wiring on obd2b to obd1 swap<<<<<<<< Please Help
Im doing a swap a obd1 B18c1 into a 1999 Civic EX. Some have told me the wiring is going to be a bitch. I have already got the harness to convert obd2b->obd1 on the ecu and have a P72.
I also replaced the injectors,and the alternator. Now im hearing people say the actual harness in the engine bay needs to be all rewired im using the d16y8 engine harness for this swapped i think the only sensor left is the CKF sensor.
Can anyone give me some knowledge on this? Or what all I need to know about the wiring and installing the motor.
The motor is in the car right now and she will not fire up i checked all the grounds,fuel pressure,main relay the fuses under the dash and the fuses under the hood.
The motor cranks but will not start up did i do something wrong with the wiring
just shoot me some ideas as to what i should check for next...
I know the motor was in working condition since i bought this motor from a friend who recently totaled his car
Re: Need help with wiring on obd2b to obd1 swap<<<<<<<< Please Help (kr)
Can someone take a picture of there thermostat ground? I here that there is a ground on the harness but my d16y8 harness doesn't have one so i put a ground from the neg battery stright to the thermostat housing the engine cranks but will not start.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kr »</TD></TR><TR><TD CLASS="quote">still needs help</TD></TR></TABLE>
did you check all the basics getting fuel? getting spark? compression test? timing?
Re: Need help with wiring on obd2b to obd1 swap<<<<<<<< Please Help (mikegee
also try this https://honda-tech.com/zerothread/1483855
kr
04-19-2006 02:33 AM
