Has any one see this before a 3.47 Final drive?
Has any one see this before a 3.47 Final drive? Does any one no what it came out of?This is a ad for a B-series powered Mini!
"Final Drive Gear Set
We now offer a Gear Set for a Y21 Transmission. This Final Drive Gear Set will result in a more desirable RPM
at highway speeds and also increase gas mileage considerably for your converted Mini. The Gear Ratio of
MiniTec's Final Drive is 3.47 Verses Stock 4.40. "
Re: Has any one see this before a 3.47 Final drive? (Dyagciog)
That looks like a misprint.
A Y21 is is a B16A/CTR/USDM ITR trans, with a 0.848 5th gear and 4.40 axle ratio, 3.7312 final.
If you swap a 5th from a GSR (0.787) with the same 4.40 axle your final drive will be 3.4628.
Sage Racing sells a 4.09 axle ratio gearset that will give you a 3.468 final drive w/ 0.848 5th. <--that looks like what they meant.
jdmcivicferio
12-05-2006 09:14 PM
