need engine swap advice
Old Apr 19, 2006 | 11:11 PM
bauer10's Avatar
Default need engine swap advice
will a d17a engine fit into a 1990 honda civic hatchback? like is it possible? cuz i need a new engine and i know a guy selling that engine its form a 2004 civic
Old Apr 19, 2006 | 11:48 PM
aaronhume's Avatar
Default Re: need engine swap advice (bauer10)
it should bolt up to your tranny but you will want to either use your 1990 wiring harness or convert to OBD-2 which the D17 uses.... either way wiring will be interesting.
however, it depends on how much the guy is selling the engine for... because it would almost seem smarter to get a different engine, maybe the D16A6, much less wiring (unless thats what you have already) and pretty cheap too, and at 108 hp its not far behind the d17, but it all depends on costs I suppose.
Old Apr 21, 2006 | 12:37 PM
bauer10's Avatar
Default Re: need engine swap advice (aaronhume)
the engine is 1000 bucks with the tranny and ecu and axles, has 50 000 kms on it and i got a guy to put it in do u think its worth it?
BadFoxDragon
Apr 1, 2019 05:59 AM
BirdJ
Jan 11, 2018 12:42 PM
Topher75
Honda Civic (2001 - 2005)
May 28, 2013 05:09 AM
dturbo
Jan 23, 2008 07:24 AM
mexipino26
Jan 14, 2003 05:46 PM
