?WUT THE HELL IS WRONG HEAR?
Old Apr 14, 2006 | 08:30 PM
pchris52's Avatar
Default ?WUT THE HELL IS WRONG HEAR?
OK i swapped a b18a into my 93 civic had it all running problem wrong it wouldn't redline it wrap it self out at 5000 grand everytime timing is dead on i'm 100% sure on this so i dont want to hear a timing issue, but worse yet i was drivin home from college an it has died an now i cant revive it. hear is of a list of things done
Motor
compression test was great
new seals an head gasket was done
new starter
new dizzy
new plugs an wires
new 255 cc injectors from venom
new fuel regulator an filter
fuel pump running fine
no check engine
main relay is clicking after key is turn an fuel pump has kicked on
car is gettin spark in every cylinder
map senor tps sensor are getting voltage an have the correct ohms
injector have the correct ohms
same as the voltage comming through the harness
dizzy was stabbed correctly
but the egine just turns jerking like somthing wont let it be freed up motor is turning freely i just dont understand why it wont start spark plus fuel should be somthin? HELP PLEASE!
Old Apr 15, 2006 | 10:21 PM
hapexamendios 2.0's Avatar
R.I.P.
Default Re: ?WUT THE HELL IS WRONG HEAR? (pchris52)
at first glace, your spelling
Old Apr 16, 2006 | 10:26 AM
User 5426's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pchris52 &raquo;</TD></TR><TR><TD CLASS="quote">OK i swapped a b18a into my 93 civic had it all running problem wrong it wouldn't redline it wrap it self out at 5000 grand everytime timing is dead on i'm 100% sure on this so i dont want to hear a timing issue, but worse yet i was drivin home from college an it has died an now i cant revive it. hear is of a list of things done</TD></TR></TABLE>
Seriously, The Hear instead of here threw me off but was the reason I viewed the post. Your post is extremely difficult to understand. It appears that your post was edited by someone dressed in a white coat and wielding a cleaver.
Old Apr 17, 2006 | 01:33 AM
JohnnieChimpo's Avatar
Default Re: ?WUT THE HELL IS WRONG HEAR? (EsQueue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pchris52 &raquo;</TD></TR><TR><TD CLASS="quote"> but worse yet i was drivin home from college an it has died an now i cant revive it. hear is of a list of things done
With grammar like yours I'll assume you are the college's janitor.
Old Apr 17, 2006 | 04:00 PM
R.I.P.
Default Re: ?WUT THE HELL IS WRONG HEAR? (JohnnieChimpo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnieChimpo &raquo;</TD></TR><TR><TD CLASS="quote">With grammar like yours I'll assume you are the college's janitor.</TD></TR></TABLE>lol, ouch
97CWITR
Jun 21, 2011 07:13 PM
accord-h22
Feb 13, 2007 04:45 PM
patrick4588
May 26, 2006 03:14 PM
