a few ecu codes need advice
Old Jan 19, 2007 | 04:22 PM
the4g4d's Avatar
Default a few ecu codes need advice
just finshed up lsvtec in a crx. right now its running obd0 .i have 3 cels , ect, iacv,electrical over load. i have all the colant lines to the manifold looped and no coolant lines to the iacv. so just coolant lines on the motor. could that throw the iacv and ect cels? i had most of the lines blocked off in my ls and never had a problem with it. as far as the electric over load cel...a short in wiring maybe?
Old Jan 19, 2007 | 04:26 PM
oneslowstd's Avatar
Default Re: a few ecu codes need advice (the4g4d)
ELD I believe you have to replace the black fuse box or there is a fuse underneath the black box, its a one time use ordeal. I also removed my IAC when I put a aebs mani on. Never had a prob either.
Old Jan 19, 2007 | 06:45 PM
fuckaBitch16's Avatar
* B A N N E D *
Of course thats why your throwing the IAC cel. And that helps with your idle, so I would hook that up. Its not hard and you gain nothing by not hooking it up.
Old Jan 20, 2007 | 04:22 PM
the4g4d's Avatar
Default Re: a few ecu codes need advice (fuckaBitch16)
IAC had a wire fucked up. No more code. however still throwin ECT and electrical system overload. any ideas?
Old Jan 20, 2007 | 09:08 PM
JasonST's Avatar
For the ELD code u can check ur battery terminals, I had corrosion on mine and that gave me the code ur getting. As for the engine coolant temp code check the sensor connector, make sure its hooked up right, and if u can't find anything wrong with it replace it.
DarkElfTRP
Honda Civic (2001 - 2005)
Oct 5, 2006 11:25 PM
Rudelude22
Nov 6, 2005 01:58 PM
pinoyboy204
Jun 8, 2005 07:32 AM
slowman
Jul 19, 2002 02:54 PM
