b18c1 into my 97 civic which ecu to use???
im trying to get ready to do this swap. can i use the stock ecu or do i need a stand alone set up such as hondata?? its a na motor no turbo just cams, valves, valve springs, typr r intake manifold and thats about it. thanks for the help.
Re: b18c1 into my 97 civic which ecu to use??? (turbocivi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbocivi »</TD></TR><TR><TD CLASS="quote">im trying to get ready to do this swap. can i use the stock ecu or do i need a stand alone set up such as hondata?? its a na motor no turbo just cams, valves, valve springs, typr r intake manifold and thats about it. thanks for the help.</TD></TR></TABLE>
do you have a b16/type R head, if not how the fack do u have a type r intake mani? you can use an obd2a P72, but throw a code for the secondaries or use a 97-98 tpye R ecu or get a chipped p28 and a jumper harness
97 CIVIC EX
08-18-2002 06:48 AM
