Which ECU and Harness for B Series-CRX Swap?
For JDM ITR engine swap into '91 DX CRX, what OBD1 ECU to use and what OBD1 harness to use. I want to go with OBD1 and not slicing the DX harness. Thanks
Guest
Posts: n/a
Re: Which ECU and Harness for B Series-CRX Swap? (CW-ITR)
Rywire one stop shopping...send them both engine harnesses, your cars and the engine you want in...they will make you a custom harness with obd0-obd1 jumper specially designed for your engine, best of all looks nice and takes 10 min. to install...if going with obd1 ecu your ecu of choice will be a p28 92-95 civic ex/si 5 spd ecu chipped with a GOOD ITR specs...
pane93civhb
02-15-2005 12:35 PM
