Swap info.,.,.
Old Jan 10, 2007 | 05:09 AM
Hatchman98's Avatar
Default Swap info.,.,.
I just got done doing a swap and the speedometer does not work and vtec does not engage. I also have a check engine Light does any one have any ideas on what could be causing this issue??? Thanx
It's a B16a JDM motor ..... and trans... in a 98 civic ek hatch w. obd2-1 harness.. and stock ecu from b16a
Old Jan 10, 2007 | 05:12 AM
firetech's Avatar
Default Re: Swap info.,.,. (Hatchman98)
Pull the codes first. The VTEC will not engage with the VSS (Vehicle Speed Sensor)not working.
Bleakened
Jul 9, 2017 08:18 PM
phelpsj2
Mar 29, 2011 04:11 PM
