What VTEC solenoid to use
I have an ITR head I am doing a B20/Vtec with, but it was bare when I bought it. I have heard that you have to use different VTEC solenoids for different heads? Is this true or will any one work?
Re: What VTEC solenoid to use (efKART)
ive heard that jap ecu's wont operate uk or us solenoids and vice versa so use the same countrys solenoid as the ecu you use. any 1 will work if you going obd1 then id use a b16a2 one as they have the oil pressure switch on them that you will need to run the ecu
showtymers619
04-14-2004 11:00 PM
