96-00 civic rear disk conversion
Ok fellas i've done some searching and w/ limited access to the internet at work I can't find what all I would need to convert my rear drums on my 96 civic coupe to rear disks. Can i use the set up off a teg and if so what all do I need to do this. Are the only diff the lower control arms? Will the rear disks off a DA work?
Re: 96-00 civic rear disk conversion (Si Equals Yes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Equals Yes »</TD></TR><TR><TD CLASS="quote">Would the brake master cylinder have to be replaced?</TD></TR></TABLE>
No
No
Re: 96-00 civic rear disk conversion (BlueIntegraBoy)
thanks man, i appreciate ur help. which lower control arm do i use? the one out of my car or the one out of the teg?
Re: 96-00 civic rear disk conversion (twotonecivic)
use your lower and upper control arms. Also use the civic 'angle adjuster'? (used to adjust the cars toe in/out)
I've also been wondering about the brake conversion for my 96 hatch, currently i can get everything I would need of of some DAs being parted out, I was thinking that I might as well pickup the whole suspension/brake setup, brake booster, master cylinder, and proportioning valve
Is there anything that should be pointed out to me, will some things not work on my ek, and/or need modifications to be setup properly other than modding the brake lines concerning the master cylinder and proportioning valve
Dont you also need the brake lines from a 99-00si? And also you have to change to a 40/40 proportioning valve.
fraknstien
05-12-2006 04:08 PM
