what do i do with the crank position sensor?
Old Dec 21, 2006 | 03:09 PM
sillyme77's Avatar
Default what do i do with the crank position sensor?
i'm using a obdII ecu. the plugs are different from the 98 ex harness to the 96 gsr b18c1 crank position sensor i'm using. the civic harness uses a 3 prongs ckp sensor plug and the gsr is a 2prong. is there a way to bypass this or fix it? thanks
Modified by sillyme77 at 5:42 PM 12/21/2006
Old Dec 21, 2006 | 03:54 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: what do i do with the crank position sensor? (sillyme77)
http://www.ff-squad.com/technet/ckftrick.htm
Old Dec 21, 2006 | 04:42 PM
sillyme77's Avatar
Default Re: what do i do with the crank position sensor? (HondaPartsHero)
it's a 96 gsr motor. the sensor and plug is there. isn't there a easier way to do it?
mikej33
Jun 5, 2015 09:44 AM
aznlaoboi315
Sep 9, 2007 02:59 PM
silver ek
Sep 5, 2005 08:03 AM
FROSTDC2
Jul 27, 2005 09:08 PM
