b17a1 from integ gsr swap to 98 civic ex
hey guys im new here, I have searched and need some straight answers
I have a 98 civic ex 5spd.
Engine and tranny I pulled last night
I have a built bottom and top end b17a1 from a 93 integra gsr, its obv obd1
This is my first swap
Im looking for a complete list of parts im going to need and not need to do this
I need to know exactly what motor mount brackets i need, what axles, what computer what everything and compatibility so I dont screw this up.. Any help is greatly appreciated as I look to get this project started within a month, Id like to get all the neccessary parts by then
Or if theres any detailed how to's for this in full anywhere Id appreciate that, thanks guys!
Re: b17a1 from integ gsr swap to 98 civic ex (dodgeavengerturbo1)
you need 99 civic si rear t bracket...this is a must
a p28 ecu will be perfect for your swap(obd2-obd1 conversion)
any bseries axles will work as long as you have the matching intermediate shaft
civic si shift linkage
thats all i can think of off the top of my head
good luck
good luck
Re: b17a1 from integ gsr swap to 98 civic ex (1sloej6)
you can use any b series shift linkage, including 90-93 integras(the only difference bettween these and 94 up is that the linkage bars are thinner). The only B series linkage you can't use is the del sol dual cam vtecs and Crx b series linkage because they are too short. This should broaden your options a little, good luck.
acurafan
05-08-2006 01:35 PM
Grimmi03
06-10-2004 07:51 PM
hobo79
08-26-2001 02:27 AM
