ANOTHER SWAPPED EG....
Old Dec 27, 2006 | 02:01 PM
lCHaCHeel's Avatar
Default ANOTHER SWAPPED EG....
i just swapped a b18b1 into a 92 eg hatch well i turn the car on and the idle climbs to 4k it might clib higher but not knowing whats gonna happen i always cut it off before it gets past 4k so i want to see if anyof u guys have came across this problem i already did a search and checked my vaccums and clean/replaced the iacv what else could it be??, im also pretty sure the timing is off could it be that??? any info would be greatly appreciated
Old Dec 27, 2006 | 04:37 PM
lCHaCHeel's Avatar
Default Re: ANOTHER SWAPPED EG.... (lCHaCHeel)
Old Dec 28, 2006 | 06:24 AM
EssEg's Avatar
for the hell of it, disconnect your throttle cable and try starting it agian
Old Dec 28, 2006 | 06:35 AM
EssEg's Avatar
Default Re: ANOTHER SWAPPED EG.... (EssEg)
also are you running a stock IM or is it after market
Old Dec 29, 2006 | 10:43 AM
delslo93's Avatar
stuck throttle body or maybe a vaccum leak
Old Jan 2, 2007 | 09:38 AM
Jack ffr1846's Avatar
I vote for vacuum line disconnected.
I'm pulling apart an EG with a B18c1 in it and paring down the wiring harness while I'm at it (it's going in my CRX racecar). I start the car about every 4 wires I cut out just to be sure it's ok. I had removed the vacuum line from the brake booster and left it open in my removal process and it did exactly what you describe. Look for a big vacuum leak....I'd start at the brake boost line.
jack
EG92DX
Apr 13, 2013 06:30 PM
lCHaCHeel
Jan 2, 2007 03:19 PM
ReVaLoT
Mar 24, 2005 09:23 PM
Mugen_R
Jun 29, 2001 02:14 AM
