D16z6 in a EK HELP FAST!!!
I have a 97 civic CX shell i picked up for 300 dollar for a winter beater.. My friend has a 93 d16z6 he said i can have for free what do i need to put this in the EK. Mainly i dont know what to do about harness and ECU i have a 94 cx harness and a p28 what do i need to have this 300 dollar car move????? PLEASE HELP
Technical Hero
Re: D16z6 in a EK HELP FAST!!! (ONELIFEMOTORSPORTS)
Your best bet is this:
1.P28 ECU
2. OBD2-1 ECU adaptor harness
3. OBD2-1 Distributor harness
4. Either get an OBD2 alternator or OBD1 alternator and swap plugs over (http://img.photobucket.com/albums/v130/fobtions/alt.jpg)
5. Convert to a 2 wire IACV from the 3 wire that the CX harness has
6. Either use some OBD2 injectors or use the D16Z6's injectors with OBD1 injector plugs soldered on
7. If you still have the CX engine harness you'll need an O2 extension harness to run the O2 where the Z6's location is
8. Get an Intake air temperature harness plug and convert the CX's plug over to the OBD0/OBD1 style
Any questions PM me
1.P28 ECU
Any questions PM me
Re: D16z6 in a EK HELP FAST!!! (HondaPartsHero)
I did not mention that this CX harness and ECU setup im using ran my B16 in my EG.. Does this make a diffrence on the IACV and O2 sensor???? THANX HONDA PARTS HERO!!!!!!
Technical Hero
The 96up Civics used a one piece harness that connected to the engine and went to the ECU. 95 and older civics and at least 92up integra's used a two piece harness: engine to strut tower and strut tower to ECU. So you won't be able to just plug up that harness you have. But you may be able to use some plugs off it to make it work or possibly get the other side of the OBD1 harness to the ECU but I am not sure that it doesn't have other plugs that run under the dash or not.
got it solved got a b20 from the junkyard for so cheap 125 dollar.. Cant beat that but thanks man i put your E-site in my favs i no you will here from me again THANKS FOR THE HELP!!!!!
Mad-Mike
11
06-23-2011 03:40 AM
