Really Weird Problem..98DX w/ B16
Hey guys, Im working on a friends car trying to get it running right, the rundown is a 98 DX with a B16A2, with a EX harness, and a OBD2A-OBD2B conversion harness running a P2T ecu. He bought the car already swapped.
The car was running fine, then took it to the paint shop and got it back and now the car dies. It cranks fine, then will run for a min and just die. At first it would loose spark so we put on a known good distributor, that didnt solve it. New plugs and wires, still same thing. Now the car consistently has spark but sounds like it is running on 2 cylinders and barley starts. Compression is fine as well. Im completely lost on what to check next...TIA
I'm really 2slow
Re: Really Weird Problem..98DX w/ B16 (RotiEatter)
maybe its running on 2 injectors like how mine was what kind of wires is he using?
have you checked the grounds?
I'm really 2slow
you can tell if its running on 2 injectors by putting your hand in the exhaust tip. If its running good it will flow smoothly, if the gas pauses for .5-1 second you might have a problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2FAST4U831 »</TD></TR><TR><TD CLASS="quote">you can tell if its running on 2 injectors by putting your hand in the exhaust tip. If its running good it will flow smoothly, if the gas pauses for .5-1 second you might have a problem. </TD></TR></TABLE>
Easy way is to pull a spark plug wire (while the car is running). If there is no change, it is that cylinder is dead. If a noticeable change, that cylinder is good.
DO NOT ground yourself to the car.
CELs?
CELs?
Re: Really Weird Problem..98DX w/ B16 (2FAST4U831)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2FAST4U831 »</TD></TR><TR><TD CLASS="quote">that too hey Kenny, will a faulty injector throw a CEL on that obd-2b ecu?</TD></TR></TABLE>
Jump the service connetor, it will still be a code 16 (curcuit) or a code 43
Quickridez_3
02-27-2009 03:22 PM
