How to tell motor is OBD1 or OBD2?
Re: How to tell motor is OBD1 or OBD2? (logiT)
There's a couple different ways. The best way is on the front of the engine block should be a number pressed onto the engine saying the year it was made, the last 2 digits (93) for example. Obd1 vtec engines have vtec pressure valve whereas obd2 vtec motors don't. Obd2 motors also have extra sensors, like secondary o2 sensor.
Re: How to tell motor is OBD1 or OBD2? (JasonST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonST »</TD></TR><TR><TD CLASS="quote">Obd1 vtec engines have vtec pressure valve whereas obd2 vtec motors don't. </TD></TR></TABLE>
All US VTEC motors have the Vtec pressure switch. It's some euro and jdm motors that don't have it.
Re: How to tell motor is OBD1 or OBD2? (4thgenhtch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4thgenhtch »</TD></TR><TR><TD CLASS="quote">Obd2 motor=Crank sensor on the timing cover
Obd1 Motors=Crank sensor in the dist
That is a flucuation sensor on the crank.
The sensor that the ECU uses for crank position is still in the dizzy.
Re: How to tell motor is OBD1 or OBD2? (F20Cteg)
My bad i realised that after I posted When i remembered you can use a obd2 distributor fine w/ obd1
Rcp
Northern California (Sales)
19
07-09-2007 07:22 PM
