Engine harness woes
Engine harness woes
Ok I have searched but I cant find a solid answer on how to fix it. 2000 civic si. 96 jdm b18c, 98 civic ex engine harness obd2a. How can I get the OBD2a engine harness to work with the obd2b chassis harness. The vtec, tach, speedo, and fan arent turning on. Everything else works. What wires need to be repined and where? Any help is appriciated.
Thanks
Thanks
Re: Engine harness woes (ultimatehonda)
The simple answer is to get your hands on a 99-00 Si engine harness. If this is not possible you will have a bit of wiring to change mainly concerning the plug C131 (Green Plug By ECU) in order to get everything working right.
OhioSI
01-17-2017 09:12 AM
ArchAngel Sabastian
01-13-2003 12:08 PM
