Wiring A B18 Into A 86 CRX, Please Help
Old 01-25-2007, 05:53 PM
DSK 86CRX's Avatar
Default Wiring A B18 Into A 86 CRX, Please Help
alrighty guys i need help with the wiring, i have everything hooked up all the fuel and water lines, i don't have vacuum lines hooked up but i figure i can get the engine running with out them, now im down to the last part, wiring...so the wires that i need to add to the ecu are, 3 from the dizzy and 2 from the eacv(i believe thats it) on the back of the intake manifold, now my question is where do these 5 wires go, i think i know where the blue/yellow eacv goes, but i dont' know where the black one wiht it goes. then i have no idea where the dizzy wires go, the colors of those are: blue/yellow, blue/green, and white, can you guys help me in any way that would be aweomse
here are some pics of my wires just so you guys can see what im talking about
the a plug showing that there is already a pulg in a-11, its the green one
here is a pic of the dizzy plug
now from the back of the dizzy plug, you can see the seperate wires that i need to add to the ecu, the ones on the right
what i believe is the eacv plug
from the side
there is a black/yellow wire and then a blue/yellow wire
this is where it goes on the back of the intake manifold
Old 01-26-2007, 12:44 PM
crxforum's Avatar
Default Re: Wiring A B18 Into A 86 CRX, Please Help (DSK 86CRX)
Sorry I cant help you, but a little sugestion while taking pictures.
On your camera you should have a Macro setting. Macro mean close up shots of stuff. Notice how in your images the things in the forground are blurry, but the background is clear? Thats because the camera is unable to focus too close. You have to change your camera to Macro to take detailed close up shots of things like your Dizzy wiring.
The macro image on your camera should look like this -->
Sorry I cant help you with your problem, but it might make it easier for other people reading this thread if the images were clearer.
Good luck on your swap.
CRX Forum
Old 01-27-2007, 08:36 AM
DSK 86CRX's Avatar
thanks man, i actually think i figure out the wiring last night, but i have to wait until i get back to my house on sunday to try to start it, but thanks for the tip on the cam, im still learning to use that thing
DSK 86CRX
01-25-2007 05:28 PM
BlackEG6
10-03-2006 10:09 AM
hatchinprogress
01-15-2006 07:42 AM
gocivicgo
05-16-2003 01:45 PM
Quick Reply: Wiring A B18 Into A 86 CRX, Please Help
