Car wont crank after auto-manual swap...
We did the swap and are using the proper computer. You can hear it priming the fuel. But when we try to start it you just hear the relay click in the underhood fuse/relay box. its the middle relay that is clicking. Where should we start looking?
Re: Car wont crank after auto-manual swap... (blufke)
that blue box? yeah, we took that out.
Re: Car wont crank after auto-manual swap... (VTECVillain)
There's more to it than just "taking it out." You need to find the Park wire on one side of the auto switch selector, then the gear input on the other side and hard wire those together. Even though your car is now a manual, the wiring is still auto going to the ignition. Don't forget to run the wires for your revers lights out to the tranny or they won't work when you put it in reverse.
i am having the same problem i used a 98 wire harness that was already on the b16a and put it in the 99 civic the car turns over but the fuel pump will not turn on, can some body please tell what to do and what blue box are you talking about and where is that blue box
Re: Car wont crank after auto-manual swap... (b18c-93)
the blue box is in the underdash fuse area. im not sure if your car has it. we got it working. set the slider(auto "gear selector") to neutral and made it stay there.
Re: Car wont crank after auto-manual swap... (ekhatchhybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekhatchhybrid »</TD></TR><TR><TD CLASS="quote">i did the same thing i was dissapointed until i put the auto slider from park to nuetral it started right up </TD></TR></TABLE>
thats exactly what we did. it just says hes in neutral(still has AT cluster)
