Will Vtec not work if the coolant temp sensor is not working?
Old 04-05-2003, 04:28 PM
KevronsEG's Avatar
Default Will Vtec not work if the coolant temp sensor is not working?
i put a d16z6 in my obd0 crx and converted it to obd1. i added the vtec wires and light to see if it works. No light. no codes. only thing is my temp gauge is wack it never reads right. It will be normal then totaly cold then whatever it wants. is my car thinking its not warm so it wont hit vtec?. what camn i do? THANKS
Old 04-05-2003, 04:56 PM
nsxmatt's Avatar
Default Re: Will Vtec not work if the coolant temp sensor is not working? (CIV616)
If the coolant temp sensor doesn't work then you won't have VTEC. Engine needs to reach operating temp before the ECU will allow VTEC to activate, unless you have a vtec controller.
Old 04-11-2003, 03:36 PM
RuffRhyno's Avatar
It could also mean that you have air bubbles in your coolant. This would result in the heated cooling running over the sensor, causing the temp gauge to rise. As soon as an air bubble hits it it could fluctuate, then when coolant hits it again go back. Try running your car for a few minutes with the radiator cap off and your heater on full blast. If you have air bubbles they should be forced out of the radiator.
92lx
11-10-2012 11:55 AM
924doorEG
01-15-2009 11:22 PM
Toe_Knee
03-26-2008 09:50 AM
loudandlow
12-15-2007 08:30 AM
Grandprix
11-29-2002 06:48 AM
Quick Reply: Will Vtec not work if the coolant temp sensor is not working?
