obd2 swap questions
Old Apr 5, 2003 | 11:40 AM
743power's Avatar
Default obd2 swap questions
I'm going to be helping a friend swap the motor from his totalled gsr into an ls. His gsr is obd2 and the ls is obd1. Is it possible to take the ecu harness that goes through the firewall out of the 0bd2 gsr and put it in the ls?
Old Apr 5, 2003 | 11:22 PM
743power's Avatar
Default Re: obd2 swap questions (743)
anybody?
Old Apr 6, 2003 | 04:47 PM
743power's Avatar
up up up
Old Apr 6, 2003 | 08:30 PM
JV's Avatar
JV
Who?
I have heard of people doing full OBDII conversions such as the one you are describing. If you do it this way i would assume you will need the ODBII catalytic converter also.
Why not run an OBDI>OBDII jumper harness or just use an OBDI P72 / chipped P28?
Old Apr 7, 2003 | 06:43 AM
743power's Avatar
Default Re: obd2 swap questions (JV)
Well since we have the car already, I was trying to figure out a way to use what we have. We have a complete LS with motor and a complete (totalled) GSR with motor. LS is obd1, GSR is obd2. I can take anything off of the gsr and put it on the ls, since the gsr is gong to get scrapped anyway.
Old Apr 7, 2003 | 10:39 AM
89JDMcrx's Avatar
When I dropped my 94 Ls motor(complete) into my 97 civic, I couldn't use my Ls harness. I used my civic harness, all i did was switched connectors with the LS, so that it will fit the distributor, fuel injectors and the alternator. I wanted to stay obdI. I also needed to get the OBDII to OBDI conversion kit. I don't know if this helps, but just to let you know thats what I had to do to get my car running.
80 dolla crx hf
Nov 27, 2008 05:24 AM
dc4teggiehatch
Jul 22, 2007 10:48 PM
eg6civic1538
Apr 30, 2007 06:51 PM
Gimpo
Feb 11, 2004 05:59 PM
Patron
Jan 2, 2002 02:43 PM
