B18b EG Swap Wiring question
I am doing the obd2 b18b swap in my 1992 civic hatchback and I was wondering if it is necessary to wire in the knock sensor. I am running the obd2 engine harness. I am running an obd1 pr4 ecu and I am having trouble finding an ecu pinout. I need to run the IAB and are there any other wires that I need to run. Please help.
Re: B18b EG Swap Wiring question (nwisehart)
Re: B18b EG Swap Wiring question (BVM)
so you guys are saying i dont have to wire a knock sensor wen putting a 98 b18b in a 95 civic ex if im using a p75 obd1 ecu?
Re: B18b EG Swap Wiring question (bOOsTiNSoHcVtEc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bOOsTiNSoHcVtEc »</TD></TR><TR><TD CLASS="quote">so you guys are saying i dont have to wire a knock sensor wen putting a 98 b18b in a 95 civic ex if im using a p75 obd1 ecu?</TD></TR></TABLE>
No you don't have to wire up a knock sensor because neither the ECU nor motor have one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">So a 92 LS motor will use the a stock 95 VX wiring harness with no modifacation?</TD></TR></TABLE>
You may have to unwrap some loom to extend some wires but all of the necessary plugs will plug into the motor and components as long as you keep everything OBDI, which the 92 LS is. The only wiring modification that will be necessary is to convert to a 4 wire 02 sensor.
