Header heat sheild?
Old Apr 4, 2003 | 06:52 PM
Richibahn's Avatar
Default Header heat sheild?
I know most people add aftermarket headers, and remove the heat sheild. good or bad? does it make a difference? I replaced my radiator with a bigger one from a gsr to go with the motor, but was just wondering if its a big diffrernce with cooling and what not. just a question.
Old Apr 4, 2003 | 10:06 PM
HybriDNA's Avatar
Default Re: Header heat sheild? (Richibahn)
Removing the heat shield will not cause a problem.... the only reason i think it was meant for was to protect you from direct contact, but other then that i think it keeps the engine bay about 5% cooler TOPS. If you want to keep your engine bay cooler get Thermal Wrap. It runs for about $30 and will keep you engine bay cooler.
Old Apr 5, 2003 | 07:38 AM
Richibahn's Avatar
Default Re: Header heat sheild? (HybriDNA)
sounds good man, thanks alot.
meanshyguy
Dec 12, 2009 02:55 PM
SlamminS85
Jan 2, 2006 09:29 AM
5-SpeedFreak
Jan 24, 2002 11:04 AM
Ryuji
Dec 27, 2001 12:25 PM
