1996 Civic EX with a PRELUDE swap
i am interested in some answers of the following in my swap.
What type shifter to buy...civic or prelude?
Do i need a new radiator?
Cold or ram intake?
What type break system?
and any other reccomendations! thanks alot
Cold or ram intake?
Re: 1996 Civic EX with a PRELUDE swap (Ddogz15)
I recommend you wait around a read before undertaking this swap.
Also, cuddle up nice and close to your Helms every night to get more affiliated with this stuff. You don't seem to be a tech expert.
Re: 1996 Civic EX with a PRELUDE swap (sappsycho)
You need the entire shifter cables and shifter assembly from a Prelude or Accord.
You've gotta cut two small holes, and run the cables down through one of them
Cold air. Del Sol VTEC radiator. 11" Fastbrakes upgrade, good shocks, and some good springs.
Re: 1996 Civic EX with a PRELUDE swap (H22EK)
I don't mean to hijack this thread or anything, but I seek much of the same information as the orginal poster.
I will be swapping a H22 into my '96 EX soon and I have a few questions.
1) If I use the HCP mount kit, what shift linkage will I need? Custom made or what?
2) Will I need a new throttle cable, or do I need to modify the existing one? Or neither?
3) What hoses (radiator, etc.) will I need? Or do I need to cut some?
4) Will I be able to keep my power steering with the HCP mount kit?
I was going to make my own topic, but since this person is researching the same thing as I, I thought I'd ask here first.
[Modified by Kyoji, 3:02 AM 4/9/2003]
Re: 1996 Civic EX with a PRELUDE swap (Kyoji)
2) Not sure, dont think so
3) Upper radiator hose: 90 teg LS
Lower radiator: 94' Del Sol Vtec
4) i hope so, but not sure
im 2 for 4, anybody else follow that up?
Re: 1996 Civic EX with a PRELUDE swap (redlineh22a)
1) You'll need shift cables from a 91' or above accord or prelude. and assembly
2) No clue. Probably not. Just run it to the bracket and tuck away the excess somewhere.
3) What he said.
4) You'll probably need to re-do the Civic's PS hose to fit the H22 PS pump. (Just run w/o it, build some muscles! )
Re: 1996 Civic EX with a PRELUDE swap (98CTRCoupe)
Thanks for all the info, I've been trying to make this swap as painless as possible. and to all.
[Modified by Kyoji, 4:16 AM 4/9/2003]
yes you can keep ps and a/c but you have to get new brackets for each and its a tight *** fit.
HCP and HAsport both make the brackets you need I believe
i have the shift linkage and place racing mount kit for sale. pm me if anyone is interested. the mount kit bolts up directly with no hammering to the sub frame.
Boosted Power
05-17-2021 02:07 AM
Twilightepitaph
Texas -OK -LA (Sales)
11-30-2007 06:44 PM
rycbrnr81
02-20-2007 11:01 AM
paulzy
11-22-2005 03:03 PM
Boosted Power
08-16-2005 06:18 PM
