best setup?
Old Apr 6, 2003 | 12:26 PM
redexchris's Avatar
Default best setup?
Hey yes i'm back with more questions, first i was asking about h22a swaps, then the girl in scc with the hatch that her bf hooked up that killer set up with the b18 or something turbocharged that ran like 12's, well thats what i want, i want to know the best engine swap with be the best for a turbo setup that i will not have to run crazy boost thats unsafe, if there is such a thing, it will be for my 95 ex coupe ,thats almost paid off, i will have a good amount of money from my enlistment to the usaf if i pass the test on tuesday, this is what i have planned i have no mods, and when i have the money i'm going to go all the way, new disk,wheels, suspension ,seats, engine everything, plus if you have est times, i would like to run 12's,
Old Apr 6, 2003 | 02:51 PM
Mentat Ghola's Avatar
Default Re: best setup? (redexchris)
b20 (non-vtec) turbo. low end torque with high end boosted power.
Old Apr 6, 2003 | 03:51 PM
redexchris's Avatar
Default Re: best setup? (The B Man)
hey thank you, would you know any est hp or times i would run, i am going to build the engine up before turbocharging it,
Old Apr 6, 2003 | 09:01 PM
intekragsr's Avatar
I would get either a GSR swap or an LS/VTEC, not a B20/Vtec unless you plan on resleeving a B20 block. The sleeves are weak.
Depends on your budget. Me personally would go GSR, Golden Eagle Sleeves, Pisont/Rod combo and some good TUNING. The only reason I went ls/vtec is I sorta just....fell into it. Long story.
If you are interested in some outputs of these setups, go to http://www.importreview.com and go to their turbo dyno section to see all kinds of setups and the numbers they put out.
Old Apr 6, 2003 | 09:02 PM
intekragsr's Avatar
BTW, you will get much better responses if:
you posted in the forced induction area
and you gave more details about what your goals are besides something you saw in a magazine.
Old Apr 6, 2003 | 10:56 PM
biassj's Avatar
Default Re: best setup? (intekragsr)
Run a GSR block, just sleeve and bore to a 2.0. Better rod ratio then ls.
ls vtec is cheaper, but above is the best.
Old Apr 7, 2003 | 05:23 PM
redexchris's Avatar
Default Re: best setup? (biassj)
http://www.importreview.com did'nt work, what is a good site that i can get a whole engine and tranny ,besides, hmotorsonline.com ,streetimports.com, and would it be cheaper to go b18b, new pistons,rods,and all cams, all new internals then a T/3 or T/4 kit on that, thank you for your help i'm still learning, and is there any more sites out there that have a good amount of engine set up that put out 12sec 1/4 times, thanks guys, oh yea and i'm not going to have any nitrous,
Old Apr 7, 2003 | 11:37 PM
intekragsr's Avatar
http://www.importreview.com/main.html
delsloturbo
15
Sep 29, 2007 04:14 PM
IAcivicEK
Apr 29, 2007 09:41 AM
xtegb16x
Apr 29, 2006 11:06 AM
Luchini
Nov 3, 2003 04:50 PM
cash459
Jan 30, 2003 04:51 AM
