ZC Problems!!!
Old Apr 3, 2003 | 04:31 AM
WhatThaFrig's Avatar
Default ZC Problems!!!
We just finished a ZC swap in an 89 Dx hatch. The car idles ok but only revs to 3000 rpm and then starts to bog down. We used an ECU from an 88-89 Integra. It is flashing codes 4,5,10,15. I belive they are crank sensor,map sensor, and EACV sensor codes.Also does anyone have a layout of the vacuum lines? We may have some crossed. Any help would be appreciated.
Thanks,
WTF
Old Apr 3, 2003 | 05:25 AM
UpstateCivic's Avatar
Default Re: ZC Problems!!! (WhatThaFrig)
PM ZC_CRX, he just finished that swap in a 91 DX this weekend. He'll help ya trouble shoot.
Old Apr 3, 2003 | 05:49 AM
Default Re: ZC Problems!!! (UpstateCivic)
Thanks,I'll do that.
Old Apr 3, 2003 | 07:03 AM
Hondasaurs's Avatar
Check all of your sensors. You may have some of them pluged into the wrong place. The TPS and EACV plugs are too short and they must be extended. Also be sure to switch green/white and yellow/white wires on TPS.
This may help you http://www.hybridgarage.com/tech/4gt...-zc-wiring.htm
Old Apr 4, 2003 | 09:17 AM
civicracer_007's Avatar
hey, I have the same problem with my D16 powered civic except my ecu only throws 1 code and thats the IAT. If you find anything out on it get me back.
thanks
WindZC
Sep 8, 2003 04:03 AM
Hondasaurs
11
Dec 1, 2002 12:29 PM
xtremcrx77
Oct 9, 2001 08:08 PM
