Difference in GSR and SiR B18c?
What, if any, is the difference in the GSR b18c and the SiR b18c?
I'm looking for a b18c1 motor and some are advertised one way and some the other.
Thanks
Thanks
Re: Difference in GSR and SiR B18c? (steadyeddy)
GSR B18C is JDM and i think the Sir is canadian or european. pretty sure the B18C gsr motor has more hp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steadyeddy »</TD></TR><TR><TD CLASS="quote">What, if any, is the difference in the GSR b18c and the SiR b18c?
Thanks </TD></TR></TABLE>
GS-R b18c1 is a usdm 170hp 10.0:1 compression ( could be 10.2) I might be wrong.
Sir-G b18c is a jdm 180 hp 10.4:1 compression
both has same gear ratio but in the jdm b18c you can get a optional factory lsd where the usdm b18c won't have it.
That's all I can think of right now though.
Re: Difference in GSR and SiR B18c? (Hybrid Beast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid Beast »</TD></TR><TR><TD CLASS="quote">GSR B18C is JDM and i think the Sir is canadian or european. pretty sure the B18C gsr motor has more hp</TD></TR></TABLE>
Re: Difference in GSR and SiR B18c? (SlowRedHybrid)
Since when did any civic come with a b18 motor?!?
The EK chassis SiR is the Canadian version of the USDM Si. It's also powered by the same b16a2 as the USDM Si.
Re: Difference in GSR and SiR B18c? (hypa)
We're talking about an Integra Sir-G b18c...not a civic.
And, thanks Sleeperciv for the information.
USDM B18C1 GSR = 10.0:1 170hp
JDM B18C SiR = 10.6:1 180hp
The JDM ECU has a speed governor and some years (96+ I believe) have no VTEC pressure switch.
New User
Re: Difference in GSR and SiR B18c? (VTECVillain)
JDM B18C can also be had in a Automatic version...i should know...i still have the auto tranny sitting in my backyard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain »</TD></TR><TR><TD CLASS="quote">
The JDM ECU has a speed governor and some years (96+ I believe) have no VTEC pressure switch.</TD></TR></TABLE>
The OBD1 JDM P72 ecu's facotry programming sucks *** too. If you get a JDM B18C-SiR/G engine either upgrade the ecu or use a stock US OBD1 P72 ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowRedHybrid »</TD></TR><TR><TD CLASS="quote">actually JDM gs-r is 10.6:1 c/r</TD></TR></TABLE>
thanks for the correction
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypa »</TD></TR><TR><TD CLASS="quote">Since when did any civic come with a b18 motor?!?
The EK chassis SiR is the Canadian version of the USDM Si. It's also powered by the same b16a2 as the USDM Si. </TD></TR></TABLE>
LOL
anyways...everyone pretty much already answered it for you
US b18c1= 10.0:1, 170hp
jdm b18c= 10.6:1, 180hp
and the ecu differences
LOL
Re: Difference in GSR and SiR B18c? (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman »</TD></TR><TR><TD CLASS="quote">
The OBD1 JDM P72 ecu's facotry programming sucks *** too. If you get a JDM B18C-SiR/G engine either upgrade the ecu or use a stock US OBD1 P72 ecu.</TD></TR></TABLE>
Accurate info
Accurate info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypa »</TD></TR><TR><TD CLASS="quote">Since when did any civic come with a b18 motor?!? </TD></TR></TABLE>
In the EDM a civic did come with a b18.
so the motor i stamped b18c1? mines just stamped b18c, vtec kicks in at 4400rpm, but mine has a speed cut at 180km/h so im assuming its SiR but how would i know exactly?
Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG »</TD></TR><TR><TD CLASS="quote">i swear that the b18c(jdm sirg had 10.4 compression)</TD></TR></TABLE>
In canada
In canada
Re: (LastGenEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LastGenEK »</TD></TR><TR><TD CLASS="quote">
In canada</TD></TR></TABLE>
i know that but people were saying its running 10.6. thats factor Usdm ITR compression
