B18c block.....
Old Apr 2, 2003 | 07:17 AM
broliSI's Avatar
Default B18c block.....
i have a b16a2 and have a chance to get a b18c gsr block, so of course i want to get it. My question is will my b16 head bolt directly on the b18c , or do i have to do other mods to put it on (like drill new stud hole or anything like that)? the block is a 1996 or 1997 block if that helps at all..thanks
Old Apr 2, 2003 | 07:50 AM
All Motor Rex's Avatar
Default Re: B18c block..... (broliSI)
Yes, it will bolt right up.
Old Apr 2, 2003 | 08:21 AM
Kataku2K3's Avatar
Default Re: B18c block..... (All Motor Rex)
Yup, the only thing you'll need are GSR head bolts... Just get a new headgasket and you'll be set... Peace
Old Apr 2, 2003 | 04:26 PM
lazy bum shaughn's Avatar
If you can, use your current B16 pistons in the GSR block to yield a higher compression ratio, and a new headgasket will do you good too.
xkjnboix
Mar 14, 2016 06:16 AM
aznej2
Oct 22, 2005 02:53 PM
sleeperHatch
Aug 22, 2005 10:59 PM
CrazyHB
May 13, 2005 12:29 PM
sPaRk'iT
Oct 30, 2003 08:09 PM
