i hate code 14
Old Apr 3, 2003 | 07:43 PM
wu tang's Avatar
Default i hate code 14
ok...so i hate code 14 and ive never been able to get rid of it, i have allready changed my iacv and i still have the dam code and my car was a dual port and now im runing a b16. please help me i need to get my car back out on the road.
Old Apr 3, 2003 | 07:50 PM
civicgeek9's Avatar
Default Re: i hate code 14 (wu tang)
check to be sure you connected the correct plug into the iacv.
i just had this problem with a dpfi to mpfi swap last weekend.
when it was all said and done, i had used the wrong plug to go to the iacv.... once i switched it with one that needed to be extended, my CEL went away and now the car is running fine!
good luck!
Old Apr 3, 2003 | 07:53 PM
wu tang's Avatar
Default Re: i hate code 14 (civicgeek9)
was it the plug with 3 wires? or 2 wires?
Old Apr 3, 2003 | 08:27 PM
Jason kiDD's Avatar
Your problem is that one of your coolant sensors has gone bad or you AICV is just hooked up improperly.. I dont know if you have 2 of them like the lude engine but change that and I bet your CEL 14 will go away..
A quick test would be to unplug the radiator fan when you are checkig for codes and see if you get a CEL 6..
Old Apr 3, 2003 | 08:56 PM
wu tang's Avatar
Default Re: i hate code 14 (Jason kiDD)
lol,i dont even have a fan in my car but i just swtched those 2 wires, and my car went up to 6 and then it stoped at 4 and 1/2 and now it wont rev past 3 grand. also i dont have my coolent or oil sensors hooked up, and still running code 14
Old Apr 4, 2003 | 05:06 AM
Jason kiDD's Avatar
Well there is your problem.. All the sensors work together including having a fan connected. Get all you stuff together properly then you should have less problems..
Old Apr 4, 2003 | 08:27 AM
wu tang's Avatar
cool, well im gonna go put allthat stuff in and i'll let you know how it gos by the end of the day. thanks
Old Apr 4, 2003 | 05:01 PM
wu tang's Avatar
ok..just got done putting those sensors on, i still have a code 14, but its running strong, i can take my car all way up now but when im at a stop sign, it dies. why??
Old Apr 4, 2003 | 05:07 PM
Jason kiDD's Avatar
You might have some sensors in the wrong place. Make sure all your wiring is good and you should be fine..
Old Apr 5, 2003 | 07:35 AM
SiR831's Avatar
You using the green two pin connector for the IACV?
Old Apr 5, 2003 | 05:02 PM
AzG35's Avatar
Default Re: i hate code 14 (SiR831)
Code 14 is usually an idle issue. Hondas, especially DOHC VTEC motors, must have proper idle speed or the IACV goes crazy. Make sure your idle is set at 750 +/- 50 rpms.
Old Apr 5, 2003 | 06:38 PM
wu tang's Avatar
Default Re: i hate code 14 (AzSi22)
ok cool, but now i have a new issue code 4. i replaced the plug cause the old one was messed up, but now sometimes i have the code and sometimes i dont. should i just relace the sensor?
Old Apr 5, 2003 | 06:56 PM
Jason kiDD's Avatar
Which sesnor is CEL 4 again?
Old Apr 5, 2003 | 06:59 PM
fastwanabe's Avatar
should be 2 wires.
Old Apr 5, 2003 | 07:00 PM
wu tang's Avatar
that would be ckp sensor, crankshaft position sensor, and when i dont have the code the car runs pretty good.
brian1121
25
May 17, 2013 08:42 PM
93egtypeR
24
Aug 5, 2010 01:04 PM
kevinEJ
Jun 23, 2010 11:09 PM
92GSR HB
Feb 17, 2010 08:29 AM
Big Bang
Oct 30, 2003 05:01 PM
