shift linkage PIN????
Old Apr 6, 2003 | 10:05 AM
acuravtecb18's Avatar
Default shift linkage PIN????
any one please tell me how in the hell u get the shift linkage pin out of a 00 gsr so i can get my motor out of my car it is the only thing stopping me!
Old Apr 6, 2003 | 10:15 AM
ATS*VEEE's Avatar
Default Re: shift linkage PIN???? (acuravtecb18)
find a small bolt or any small pin that has a flat end and slightly hammer it out, like a chisel.
Old Apr 6, 2003 | 10:21 AM
Default Re: shift linkage PIN???? (richierich)
oh but i did many times it will not come out i used a center punch even
Old Apr 6, 2003 | 10:34 AM
Chrislow's Avatar
spray some wd-40 on it and if you can get it out just a little grab it with some plyers and squeeze it together, should come right out then. It's going to take some patience, wait till you ahve to get it back in.
Old Apr 6, 2003 | 10:57 AM
Default Re: shift linkage PIN???? (Chrislow)
thank u very muchguys i will give it a try.
Old Apr 6, 2003 | 12:09 PM
Kamin's Avatar
uhh no
you cat grab the pin, ever seen it? there is NO WAY you will be able to squeeze it. let alone get a pliers into the linkage because the pin dosent stick out.
get an 8mm NON TAPERED punch. and beat the **** out of it.
[Modified by Kamin, 1:09 PM 4/6/2003]
Old Apr 6, 2003 | 01:13 PM
Chrislow's Avatar
Default Re: shift linkage PIN???? (Kamin)
How about you read what I ******* said?
"if you can get it out just a little"
and you can grab it, sorry if you dont have the tools or the ***** to sqeeze it hard enough. It's (at least mine and the other one I got from Honda) a spring pin. Why do you think it stays in the linkage? Just cause of that other metal piece around it? "uhh no"
Old Apr 6, 2003 | 01:22 PM
Kamin's Avatar
if you can move it a little JUST KEEP BEATING ON IT
******* jackass
and i know how the spring pin works
[Modified by Kamin, 2:23 PM 4/6/2003]
Old Apr 6, 2003 | 01:39 PM
NiiS's Avatar
The last swap I did I had to beat the **** out of that pin for 15 min before it broke free. I imagine it had`nt ever been removed...putting it back in was`nt as difficult. You need to break the seal, so to speak.
Just keep beating the hell out of it
Old Apr 6, 2003 | 03:39 PM
Blaze45's Avatar
Brrraaaap!
Default Re: shift linkage PIN???? (sinister)
Dude, are you takin the tranny out? If you are then what you need to do is unbolt the bolt that connects the linkage to the shifter, then take the whole linkage out when you pull the engine, and then pound it out when its out of the car. SOO much easier. Be sure to unbolt the selector rod from the tranny. Sorry to hear that your havin so much trouble w/ it. If all else fails, air chisel.
Good Luck
Blaze
[Modified by Blaze45, 12:49 AM 4/7/2003]
Old Apr 6, 2003 | 05:11 PM
SiRkid's Avatar
Default Re: shift linkage PIN???? (Blaze45)
the pin thats in the boot... just punch it out... it comes out easily
Old Apr 6, 2003 | 06:36 PM
b20guy's Avatar
Default Re: shift linkage PIN???? (SiRkid)
use an a/c compressor bolt. Worked for me today. "It" was the bitch I think
Old Apr 7, 2003 | 06:55 AM
Fuster_Cluck's Avatar
I used a socket extension and a hammer and whacked it about 15 good times before it flew out the top
The socket extension I used was the smallest size, sorry don't know the size.
Anyhow, put some elbow grease behind that hammer. It's not called "bitch pin" for nothing
I tried to install a new pin in my GSR swap and having a hard time. Any tips for me guys? Install from the bottom / top? Any advice will be highly appreciated!
Old Apr 7, 2003 | 09:32 AM
Trey's Avatar
25 Year Member
Default Re: shift linkage PIN???? (Hybrid93Hatch)
If you can't get it out, take the motor out with the bar still attached. :D
It IS do-able.
Old Apr 7, 2003 | 04:51 PM
Blaze45's Avatar
Brrraaaap!
Default Re: shift linkage PIN???? (Trey)
What i just said lol
Old Apr 7, 2003 | 05:57 PM
yaya's Avatar
biiiiiigah hammmmahhh
Old Apr 7, 2003 | 06:04 PM
J2turbo21's Avatar
Default Re: shift linkage PIN???? (yaya)
Try heating it up with a little torch,it might make it easier to come out.I did that with my axels cause they wouldnt come out for ****.I think i will try the 8mm flat punch sometime this week.
vtecc
Jun 1, 2015 10:53 PM
Matt_Jagg7
May 13, 2010 01:18 AM
ALLMOTOR CRX
11
Mar 29, 2007 07:34 AM
honda4674
Jun 24, 2006 12:45 AM
MR. MIYAGI
Mar 12, 2004 12:34 PM
