JDM D15B Studdering at 4000rpm????Help?????
Thought it was the timing and tried to move the dist. around a bit, but no luck. When the vtec kicks in it starts sputtering almost two wher it sounds like constant backfiring??? It started after I replaced the old dist because of a bad bearing.
Re: JDM D15B Studdering at 4000rpm????Help????? (RangerDan)
92 cx not sure exactly what ecu, but it was working fone until I had to get the new dist.
Re: JDM D15B Studdering at 4000rpm????Help????? (Touch)
Could be your o2 sensor! My friends car did this he replaced the sensor and it went away.
ph0shizzle
08-26-2006 02:49 PM
