swap problem!? very weird!?
Old Apr 9, 2003 | 09:42 AM
2trix's Avatar
Default swap problem!? very weird!?
so i dropd my h22 wired everything and at one point it did run....
this is how it ran: started kinda jerky and idle was surging a little. heres where it gets weird...the car will just rev upto a certain point then cut fuel then rev, then cut fuel...this is over and over. at this point we tried to troubleshoot some sensors.. now when the sensors are unpluged the car runs the same as if they did while plugd in!? at this point i think the ecu is running in an open loop on start mode....car runs rich, wont let rev...ect. now at this point the only thing i could think of is dist. since it runs the main functions to the ecu....pulled the cap and found cracks going to 3 of the 4 pins....so we replaced the cap and now we dont get spark!? not even out of the coil!? should we try replacing the coil!? any ideas!?
btw. the dist is jdm internal coil.
Old Apr 9, 2003 | 10:45 AM
Soled Out's Avatar
Default Re: swap problem!? very weird!? (2trix)
Is the ECU throwing any codes?
Old Apr 9, 2003 | 10:51 AM
2trix's Avatar
Default Re: swap problem!? very weird!? (Gray EG)
yes the ecu is throwing codes...also engine is obd1 and ecu is obd2 with an obd2 wiring harness (dont tell me thats my problem, i know its not the best...) i think im getting codes 7, 10, 41, 65, and 20...i dont know for sure. any ideas would be great!
Old Apr 9, 2003 | 11:25 AM
oldbeefcake's Avatar
ECU is your problem. because OBD II has more sensors than OBD I. If it doesn't detect the sensors, it will run weird. Aslo check your fuses for sparks. Don't start a project until you have all your resources.
Old Apr 9, 2003 | 11:38 AM
2trix's Avatar
Default Re: swap problem!? very weird!? (Jun)
hmmmm....well off my harness there was only one unused sensor and that was crank angle? and its not like im gettin 35-40 codes from the 300 that obd2 has, im only getting like 6, and i know for sure that one of them is going to be egr, cuz its not hooked up....
Old Apr 9, 2003 | 01:35 PM
Newman's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jun &raquo;</TD></TR><TR><TD CLASS="quote">ECU is your problem. because OBD II has more sensors than OBD I. If it doesn't detect the sensors, it will run weird. Aslo check your fuses for sparks. Don't start a project until you have all your resources. </TD></TR></TABLE>
Yup, that sounds like your classic "ECU not working" problem. Usually that occurs from either getting a bum ECU to begin with, or one that's been chipped and not soldered in correctly. Try swapping out the ECU for another OBD-1 ECU or your old stock one just to see if it runs better/smoother (or whatever year/generation ECU that you need to use to plug into your car).
Old Apr 9, 2003 | 02:01 PM
2trix's Avatar
Default Re: swap problem!? very weird!? (Newman)
tried old p2e obd2 ecu and it does the same thing...its not a burnd ecu, ecu is not the problem. could dist be causing problem? dist workd, changed caps...now neither work?
wilham320
Engine Management and Tuning
Aug 8, 2012 05:42 AM
Afshin9393
13
Mar 4, 2011 12:40 AM
silentbeatz
Dec 16, 2008 09:44 AM
Carolina Fried Rice
Dec 11, 2006 10:01 PM
musTerdh22eg
20
Feb 7, 2006 09:53 PM
