Max Power= 151.0 Max Torque= 107.0
I went to get my car dyno'd today and tuned by Tobi at Dyno Pro. I started off running real lean but the overall result was a nice gain in the mid range where I gained 15 horsepowR and 12.7 ft/tq. The top end stayed the same and the fields unit sucks for tuning since it does it by 1000rpm increments and the a/f cruve needed a little tuning in between the rpm's.
Here is the chart.
Mods:
JDM B16 Sir II
AEM CAI ('00 Si)
Apex-i GT Header
Apex-i N1 Piping w/ ES Universal Muffler
CTR Intake Cam
Test Pipe
Fields VTEC Controller
Exedy Clutch
AEM Pulleys
Fluidyne Radiator
Hondata Gasket
AEM ADJ FPR
Walbro 190lph Fuel Pump
Here is the chart.
Mods:
JDM B16 Sir II
AEM CAI ('00 Si)
Apex-i GT Header
CTR Intake Cam
Test Pipe
Exedy Clutch
AEM Pulleys
Fluidyne Radiator
Hondata Gasket
AEM ADJ FPR
Re: Max Power= 151.0 Max Torque= 107.0 (hot_EG)
not bad as far as power but not all that either for the amount of work
on average a built SOHC 1.6l will have more torque then B16A, but the curve won't be so flat.
Pretty nice curve, although when I saw the low TQ in the thread title, I figured you had a built SOHC
Re: Max Power= 151.0 Max Torque= 107.0 (futuresi)
Yeah it was tune at 5800 ft above sea level
Re: Max Power= 151.0 Max Torque= 107.0 (Maximus)
So that is where the low numbers came from. You are putting down some pretty nice numbers for where you are located.
AB16A2T
04-19-2003 02:14 PM
TedR719
04-07-2003 09:10 PM
