whats the best tranny for a b20/vtec swap
Re: whats the best tranny for a b20/vtec swap (DOHCvtecCR-X)
Any GSR/SiR/Type R transmission would be the best ideal transmission to use because of the gearing. Otherwise, any B-series transmission will bolt on and work.
Re: whats the best tranny for a b20/vtec swap (Newman)
depends if your built bottom to handle the revs.
depends on your revlimit.
depends on how you want to daily drive...
cause you can have 60mph @ 3500+/-rpms cruising
but the shortest will give you a faster time as traction permits.
Re: whats the best tranny for a b20/vtec swap (BoM)
I'm running a 92 GSR Tranny on my B20 Vtec. @ 80mph I'm right at 4900 rpm. I haven't had a problem after 6000 miles and clockin'. If you are use to your B16a tranny you'll be fine. Expect the same...
Ya wanna race
03-09-2005 05:04 PM
eathatch94
37
07-07-2004 11:08 PM
