I got 2 engine codes. PLEASE HELP!
Old Apr 9, 2003 | 05:38 PM
HybriDNA's Avatar
Default I got 2 engine codes. PLEASE HELP!
I just did a swap in my 89 CRX DX. I rebuilt a 91 B18a shortblock and put a '99 JDM b20b head on it and threw a LS tranny on it and did the DPFI to MPFI and started it up. Runs great.. only thing is that im throwing Code 7 (which is TPS) and Code 8 (which is TDC). I double checked all my wiring and still throwing these codes. Im using a 90 PR4 ECU. Can anyone help?
Old Apr 10, 2003 | 04:59 AM
VTECVillain's Avatar
Default Re: I got 2 engine codes. PLEASE HELP! (HybriDNA)
The TPS has an adjustment to it sort of like a distributor. You can move it slightly which will change the voltage so this might need to be done. I can't remember what the proper voltage is off the top of my head but I'm thinking it's 1.5V. For the TDC sensor, I would check the wiring again and then possibly change out the distributor with another to see if the code clears.
Old Apr 10, 2003 | 07:43 AM
HybriDNA's Avatar
Default Re: I got 2 engine codes. PLEASE HELP! (VTECVillain)
Hey bro... thanks for the info.... Well i dropped my dizzy on the floor a while back and it cracked my cap on the side about 1 1/2" long... you think i should change the cap out?
crxjatt
11
Jul 26, 2013 01:49 PM
scottso990
10
Aug 2, 2010 12:54 PM
E9CiViC1F
Aug 11, 2009 12:52 PM
kwizical
12
Mar 10, 2008 08:05 AM
crackercr-x
Aug 4, 2004 05:57 AM
