ecu pin outs on eg
ecu pin outs on eg
i'm trying to rewire my ecu to put back my d16z motor from a gsr swap.. I forgot wat to do.. basically i just need to undo watever i did to do the b18c1 swap so i can make my stock motor run right
thanks
thanks
Re: ecu pin outs on eg (TORQUE MONSTER)
Why don't you splice some more wires..!! Doesn't matter which ones just start cutting like you usually do
[Modified by gphybrid, 9:01 PM 4/7/2003]
The only wires added from a D16Z6 to B18C1 would be the knock sensor and intake air bypass if it's wired correctly. There should be no reason why the car wouldn't run properly by swapping the Z6 back in even if you leave that wiring there.
TurboBumblBee
02-25-2002 06:03 PM
