h22a in 98 integra
Old Apr 9, 2003 | 01:43 PM
982drLS's Avatar
Default h22a in 98 integra
anyone know where i can find some info about putting a h22a into a 98 integra.. or if anyone has done this swap let me know if its worth it or not..thanks
Old Apr 9, 2003 | 02:01 PM
junglerunna's Avatar
Default Re: h22a in 98 integra (982drLS)
I def remeber seeing a thread on it a little while ago. Ill see if I can search for it.
Old Apr 9, 2003 | 02:03 PM
Newman's Avatar
New User
94-01 Integra engine chassis is the same as the 92-95 EG Civic. Thus, doing the swap procedure is the same as doing the H22 swap into any 92-95 Civic. Only main difference will be the wiring since your car is OBD-2, depending on what year motor you get.
Old Apr 9, 2003 | 03:57 PM
redlineh22a's Avatar
Default Re: h22a in 98 integra (Newman)
http://www.HASport.com actually tells you what you need.
just search the net some
Old Apr 9, 2003 | 04:35 PM
yaya's Avatar
i dont get this part hasport says
"The mounting bracket on the right-hand framerail will need to be removed or it will interfere with the shifter assembly."
what????i thought you just had to trim the passenger side upper mount
some one explain
Old Apr 9, 2003 | 05:04 PM
Newman's Avatar
New User
Default Re: h22a in 98 integra (yaya)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yaya &raquo;</TD></TR><TR><TD CLASS="quote">
Meaning, with the HASport H22 mount kit, you need to completely hack off the passenger side bracket that's welded to the frame and bolt their parts from underneath. Only with the HCP EG-22 mount kit do you still use that frame bracket, and only trim off a small part of the rear arm only to clear the shifter assembly box.
Old Apr 9, 2003 | 05:36 PM
CvexH22's Avatar
Just drill where it was spot welded on
Old Apr 9, 2003 | 05:42 PM
yaya's Avatar
Default Re: h22a in 98 integra (CvexH22)
ohhh NICE pic, now i see how the new mount fits....
i thought with the newer hasport kit you didnt need to chop anything off....now i see you do
cool thanks for that pic
Old Apr 9, 2003 | 06:12 PM
fastwanabe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CvexH22 &raquo;</TD></TR><TR><TD CLASS="quote">
or you could use the HCP and do this
Old Apr 9, 2003 | 06:25 PM
Jonathan_ED3's Avatar
I drilled where it was spot welded on, with the exact bit that Hasport says to, and I can't get the dang thing to come off....I've drilled out all the spot welds, accidently went through to the frame rail in one spot, and the dang thing will still not come off. Even with a 15lb sledgehammer it just shakes the whole car.
Old Apr 10, 2003 | 07:50 AM
yaya's Avatar
Default Re: h22a in 98 integra (fastwanabe)
hey for the HCP you just redrill the smaller hole on that bracked right?
Old Apr 10, 2003 | 09:58 AM
H22EK's Avatar
Default Re: h22a in 98 integra (yayaRl337)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yayaRl337 &raquo;</TD></TR><TR><TD CLASS="quote">hey for the HCP you just redrill the smaller hole on that bracked right?</TD></TR></TABLE>
Yes you need to drill the hole out using the little pilot hole that is already there. If I remember correctly you need to use a 9/16 drill bit for that hole!
Old Apr 10, 2003 | 03:54 PM
jdmcivicferio's Avatar
Default Re: (hot_EG)
that happend with mine to then I got pissed off and got the air chisle out and took it off, works great.
Rybear
Mar 2, 2015 02:11 AM
shawn43
Jan 13, 2009 06:22 PM
SOJAMR1
May 12, 2005 07:13 AM
laughinxxx
Jan 1, 2002 11:38 AM
