Running a P28 instead of P13..
Old Apr 2, 2003 | 03:00 PM
CvexH22's Avatar
Default Running a P28 instead of P13..
in an H22a , will there be any problem? the p28 is stock .. what are the pro's and con's if running a stock p28 instead of P13.. thanks guys
Old Apr 2, 2003 | 03:15 PM
2trix's Avatar
Default Re: Running a P28 instead of P13.. (CvexH22)
pro: no egr and no ks codes will be thrown!
con: fuel maping not quite upto par with the p13, although this can be changed with a program chip or hondata unit.
Old Apr 2, 2003 | 03:21 PM
h22 civ's Avatar
You need to use a H22 program in the P28
Old Apr 2, 2003 | 05:50 PM
hondaeg5's Avatar
Default Re: Running a P28 instead of P13.. (2trix)
is this the only con? why then doesnt everyone just use the p28?
Old Apr 2, 2003 | 11:00 PM
k_spek's Avatar
Default Re: Running a P28 instead of P13.. (hondaeg5)
The p28 does not have secondary butterflies control. If you run with a chipped p28 on a h22 then the iabs are going to be open all the time, resulting in a lose in power and torque down low. However you can run the iabs straight off vacuum so that they only open up under half throttle to open throttle.
Old Apr 3, 2003 | 12:01 AM
prospeed's Avatar
I offer an h22a program for the p28. Hondata would also be another good choice for the p28.
rohec04
Dec 12, 2006 08:34 AM
abeaujuin
Jul 27, 2004 09:01 AM
Ddogz15
Apr 15, 2004 12:34 AM
