knock sensor question
Old Dec 10, 2003 | 09:45 AM
90Ntegra's Avatar
Default knock sensor question
i put a b16a into my 90 integra. my check engine light comes on and code 23 comes on , wich is knock sensor. its already connected and i have tried everything!!!
Old Dec 10, 2003 | 11:25 AM
Home Skillet's Avatar
Default Re: knock sensor question (90Ntegra)
Have you tried replacing the sensor? Did you check the connection at the ecu plug?
Old Dec 10, 2003 | 12:11 PM
GPoodle
Guest
Posts: n/a
Default Re: knock sensor question (Home Skillet)
Search, and you'll find you need insulated wire.
I honestly have answered this question more than 5 times in the last couple weeks >_<
Old Dec 10, 2003 | 12:57 PM
VTECVillain's Avatar
Default Re: knock sensor question (GPoodle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GPoodle &raquo;</TD></TR><TR><TD CLASS="quote">Search, and you'll find you need insulated wire.
I honestly have answered this question more than 5 times in the last couple weeks &gt;_&lt;</TD></TR></TABLE>
So have I. You should use shielded wire for the knock sensor which shields out electrical interference's from other electrical parts and sensors. There's going to be people to say "I never used shielded wire on my setup" as always. Well, they are fortunate enough to not need it, but most of the time you do. It is wired that way from the factory (get a Helm's and you'll see) for a reason.
Old Dec 17, 2003 | 01:10 PM
90Ntegra's Avatar
Default Re: knock sensor question (VTECVillain)
i have already tried a shilded wire but no results.
Old Dec 17, 2003 | 01:12 PM
The only other possibilities would be that you aren't connecting the knock sensor to the proper ECU pinout or the sensor is bad. It could also be loose in the block and might need tightened.
sir2sol
May 12, 2007 05:32 AM
2poor2tune
Oct 9, 2006 12:07 AM
Dragline
Aug 19, 2005 12:45 PM
