proper fitment... crx w/ b16a... help please!
I am interested in purchasing a short throw shifter for my manual transmission, I just dont know what application to buy for... I have a gen 1 b16a going into my 88 crx, so what year/model should i select for proper fitment of the short shifter.... thanks
Re: proper fitment... crx w/ b16a... help please! (Undrgrndhaqer)
It depends on what shift linkage you are using, I know the Hasport linkage uses the stock 88-91 Civic/CRX style shifter. If you are using modified Integra linkage then you would use a shifter that would fit same year Integra as the shift linkage. If you are using another aftermarket linkage then you would want to check with the manufacturer.
tRex99
12-21-2004 12:02 AM
ricodemus
07-24-2002 07:52 AM
